Weed Killer Recipes
/ Weed Killer Recipes #41
Does anybody know the shelf life of Roundup? I'm working through the last pint I found here in Dad's jumble of yard sale purchases. He must have found it 1999 or prior but he wasn't its first owner. No telling how old it is.
I mixed up a batch and sprayed a few ivy runners that had sprouted down in the ravine where we had dumped them as gardening debris. I don't want to see ivy get started down there. Two weeks later the poison oak and Himalayan Blackberry I also sprayed look sickly as expected, but the ivy looks like I fed it Miracle Grow. Bright green and I swear there's more of it.
How do I eradicate the ivy, and how long does Roundup stay potent after the bottle has been cracked open? Would mixing it double the label recommended maximum do the job?
/ Weed Killer Recipes #42
You were right about that 2 week deal on the Round-up Pro with mature vines. I was out there Sunday and the weeds/vines are starting to look pretty bad (which is good). We're getting rain today, so hopefully that will kick off some more growth which should allow the Round-up to work better. I'll also still get some of the crossbow stuff.
California - don't know about the shelf life, sorry but there are some pretty good recipes in this thread. I killed a vine of poison ivy in the yard by the house this summer, took two sprayings with the "household" version - not the concentrated stuff - but it worked pretty fast. Don't let that stuff get a foot hold. KILL IT!!! :mad: :D
/ Weed Killer Recipes #43
Ok this isn't working.
After another week: My maximum-recommended Roundup mix is killing the Poison Oak (red) and Himalayan Blackberry (pale green) but the Ivy I'm targeting the spray on, loves it. :mad:
Any advice?
/ Weed Killer Recipes #44
"....Make sure you add the detergent after filling up the sprayer or you'll have a mess....."
Did you learn it from experience? LOL!
/ Weed Killer Recipes #45
Never had much luck with ivy... the leaves are very waxy and seem to be very resistant unless I get them early in the spring...
/ Weed Killer Recipes #46
The spring is the best time to spray but in late fall plants will go through a growth before the sap is down. I use 1oz glyfos. to the gallon for weeds and 2oz for brush. For waxy leaves use a little detergent as a surfactant or you can even use a little cooking oil. If possible spray the bottom of the leaves of waxy plants. Also do not give up on the glyfos. I have sprayed brush that took as lond as 3 to 4 weeks to show signs it was working and later go back to find it did a good job. I have also used the 2,4-D. It is good if you have broad leaves growing in grass, and don't want to kill the grass. The glyfos. will kill almost anything if you get a good cover.
/ Weed Killer Recipes #47
reelrunner said:
For waxy leaves use a little detergent as a surfactant or you can even use a little cooking oil. If possible spray the bottom of the leaves of waxy plants .... The glyfos. will kill almost anything if you get a good cover.
Thanks! The Ivy being resistant due to wax never occurred to me. This week I'll add detergent, and try to get under the leaves.
/ Weed Killer Recipes #48
Spiveyman said:
I have another question here. Sure enough I have checked the fence line all week with little sign of any effect of the 10% solution of Round-up. Will that stuff even work in the fall when the weeds aren't as active? Will any of the other ideas out there work when the weeds are less active like now?
Thanks
This will clean your fencelines without the herbicide...
Swisher Mower & Machine Co.: Postmaster
/ Weed Killer Recipes #49
A few weeks into this thing I can report that the Round-up has worked very well. I can see a couple spots that I missed, but about 2 weeks after application I could really see a difference, and now I have alomst total annihilation! :)
I like this rout better than trimming the stuff because it's supposed to get the roots rather than just the above ground portion.
/ Weed Killer Recipes #50
Just remember that shallow rooted trees (like dogwoods) can be killed if you spray too much RoundUp under their roots/canopy (don't ask how I know :eek:) A little RoundUp goes a long way, you don't have to soak the leaves, it just takes time (and the plant needs to be growing somewhat - don't try and kill it in the Fall).
/ Weed Killer Recipes #51
I just want to add to this thread that when you use "homebrew" recipes, like salt and vinegar you are NOT being environmentally concious or minimizing your impact on your property or animals. Glysophate has far, far less residual effect than salt or vinegar or diesel fuel. In fact, you can replant within days of a glysophate treatment. Other than tracking muddy prints through the house, your animals would see no effect from walking through a sprayed area whatsoever.
The message in this thread that everyone needs to carry away with them is the fellow who plowed salt into his granny's drive and killed the grass another 10 feet either side of the drive. It will be years before that area will grow grass again.
Using glysophate to control active weeds in dormant stands works, but you have to be very careful. I have a fairly new zoysia lawn that had a lot of fescue clumps in it last winter. In early March, while the zoysia was still very brown, I mixed up a tank of glysophate to knock down the fescue. I started out using the gun, but noticed that I was going through a bunch of mix, so on the second half of the lawn, I used the boom. On the half where I used the gun, the zoysia was stunted for weeks -- brown circles everywhere I pulled the trigger. Where I used the boom the fescue and weeds died and the zoysia greened up nice and even and right on schedule.
Morals of the story are, "Dormant is a relative term" and "It takes a lot less glysophate to kill stuff than you think it does."
/ Weed Killer Recipes #52
If you want to get rid of this stuff you have to get serious. I got some ag type round up from my uncle who is a farmer and the stuff is like a golden syrup. Basically the same color as the Lowes round-up but it looks very diluted. Funny if I double up on the Lowes version mix it works twice as fast and kills everything deader! IE sometimes I only get a half dead weed that will come back. With the Ag Round-up just a dab will do ya.
I asked our local COOP what was the strongest license free herbiside I can buy was. He said Remedy. Funny that mix is Triclopyr at 61.6%!!!!
It isn't cheap but I think the per-acre mix is something like 8 oz.
Listening to our local Garden Line show this weekend he mentioned two products. One containing Triclopyr. This is the active ingredient in several products. For fence lines and such he suggested a product called Pramitol. Pramitol kills for a year because it gets into the ground. It's NOT good around trees, shrubs, etc. Nasty stuff. Since he mentioned it on a local radis show I guess these are items you can buy without a license. He mentioned it could spread as much as 5 feet in the soil.
Good Luck,
Rob
/ Weed Killer Recipes #53
I went ahead and did the work to get a pesticide license--the non commercial variety. 2 4d Amine for 2 1/2 gallons is just under 40 bucks at the Co-OP. I figure the license paid for itself just with that trip.
/ Weed Killer Recipes #55
firedog said:
Good thread so far.... Here's a good read I found concerning the addition of Ammonium sulfate to glyphosate and/or Round up.
Adding ammonium sulfate to Roundup
This is also interesting. I have hard water at the city house so my roundup isn't working well there I guess. At the weekend place, soft water, slippery stuff in the shower!!
Where/how do you buy Ammonium sulfate (AS)?
/ Weed Killer Recipes #56
The local co-op has it for around $10 per 50lb bag IIRC.
/ Weed Killer Recipes #57
At the moment I'm pretty satisfied with the Lowe's version, although I mixed it fairly potent. If the Ag stuff will kill it deader, I'm all about that. I'm probably going to be taking out many of the trees on this fence line anyway, so if I get some collateral damage I'm not too concerned. I don't want to destroy the soil permanently, but every cell that splits in that fence row is one more cell that I have to remove later.
/ Weed Killer Recipes #58
All true, but sometimes, you want permanent control. I don't think I ever want weeds growing between the bricks on my patio or driveway.
I've heard that adding a smidgen of glyphosate to 2-4-D or a smidgen of 2-4-D to glyphosate adds to their effectiveness. I've tried it, but don't notice a difference so far. Anyone try it, and how did it work?
/ Weed Killer Recipes #59
jeffinsgf said:
I just want to add to this thread that when you use "homebrew" recipes, like salt and vinegar you are NOT being environmentally concious or minimizing your impact on your property or animals. Glysophate has far, far less residual effect than salt or vinegar or diesel fuel. In fact, you can replant within days of a glysophate treatment. "
Boy I hope this is true. Down here in South Texas, the farmers spray the tops of grain stalks with a duster before harvest so they can kill the stalk and low the moisture content in the grain for a higher profit. Maybe there's a low-fat version of Round-Up? :D
/ Weed Killer Recipes #60
I got tired of cutting down Mulberry trees and having the suckers sprout back out of the stumps. One day after cutting down some trees again, I took some pure concentrated glyphosate and brushed it on the stump with a small paint brush. I coated just the area at the edge of the stump, right where the bark meets the wood.
Boy, that killed them! No more suckers and sprouts coming up from those stumps! I have done that ever since when I cut down Mulberrys or any tree that tends to resprout again, and it solves that problem. And it doesn't even kill the grass right beside the stump.
Iranch High-End Tricycle (A64119)
Iranch High-End...
2022 EZ-GO ELITE...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
MF GC2300 fel replaced
