Weed Eater Power Blower Carb Adjustment
   / Weed Eater Power Blower Carb Adjustment #1
fortyseven2n
North Carolina
1947 Ford 2N , 1952 Ferguson TO-30 , 1953 John Deere 40 Standard, 2009 Kubota L3400 HST with Loader
I have a Weed Eater model GBI 30V blower that will not stay running.
When I got it ( free ) it would crank and run great but would sputter and would cut off.
The carb only has on adjustment. I turned it to get the right mix and think I wound up getting it totally out of whck.
Turns out the sputtering was because the fuel line had rotted. I put on a new fuel line but cannot get it to run right.
The book says to turn the mix screw until it stops. Start the engine and adjust until it runs smooth.
I cannot get the motor to start unless I back the screw out about 1-1/2 turns. It will run great at full throttle but will die if I let off and then accelerate.
Any ideas or suggestions on setting the mix ?
Please help.
Thanks !
Fortyseven2n
   / Weed Eater Power Blower Carb Adjustment #2
try turning the adjustment screw out a little more and it should accelerator smoothly.
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2011John Deere 244J (A47477)
2011John Deere...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
2013 CAT 246C (A47477)
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
