Weed Eater Power Blower Carb Adjustment
   / Weed Eater Power Blower Carb Adjustment #1
fortyseven2n
Bronze Member
North Carolina
1947 Ford 2N , 1952 Ferguson TO-30 , 1953 John Deere 40 Standard, 2009 Kubota L3400 HST with Loader
I have a Weed Eater model GBI 30V blower that will not stay running.
When I got it ( free ) it would crank and run great but would sputter and would cut off.
The carb only has on adjustment. I turned it to get the right mix and think I wound up getting it totally out of whck.
Turns out the sputtering was because the fuel line had rotted. I put on a new fuel line but cannot get it to run right.
The book says to turn the mix screw until it stops. Start the engine and adjust until it runs smooth.
I cannot get the motor to start unless I back the screw out about 1-1/2 turns. It will run great at full throttle but will die if I let off and then accelerate.
Any ideas or suggestions on setting the mix ?
Please help.
Thanks !
Fortyseven2n
   / Weed Eater Power Blower Carb Adjustment #2
try turning the adjustment screw out a little more and it should accelerator smoothly.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
