Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #1
Captain Dirty
Platinum Member
Eastern Mass
Goldoni 600, Kubota L45
My 78" Lorenz snowblower was fitted with "inverted mushroom" skid shoes. The disks are 6mm (1/4") thick, 8" in diameter with approx 1/2" of concavity welded to 1-3/4" pipe shafts. In 9 winters I wore them out. As the upturned edges remained full thickness, I hadn't given them a thought until I saw a disk lying in the snow. The center had worn thin enough to tear where welded to the pipe. As the replacement cost (with shipping) was about $100, I had no problem ordering another pair of skid shoes.
I am considering 1) welding strips of 1" x 3/16" mild steel in 6 rays (like an oversized grade 8 bolt) as wear strips that also act as wear indicators, or 2) laying beads of hard facing weld (Airco 388 -5/32 rod is what I have) in a star pattern, or 3) both. What has been your experience and is your recommendation?
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #2
There should be welding rods available for hardsurfacing.
You should also be able to find a pattern that suits your needs.
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #3
I have used 1/4" Stainless steel in a pinch wears better than mild steel Hardface rods are available and used with a checkered pattern will wear well. Don't expect a nice looking bead, the stuff runs like crap. Dosen't need to look pretty anyway.
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #4
I recently purchased a set of wear shoes in the mushroom pattern from the local NAPA parts outlet.
They were not expensive at all . less than $50 a pair with spacers and pins. The wear shoes are cast iron.
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #5
Have the same style inverted mushroom shoes on my Lucknow (I added them) and I hard rod the bottoms with Lincoln earth contact hard rod. Problem is, it's expensive at 15 bucks a pound so just buy what you need. I run it at 150 amps reverse polarity.
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #6
I noticed that I'd worn out my shoes on my Honda blower. thing is it didn't take long.
So I rebelled. I installed half-inch steel shoes. Rounded the lead edges put in slots for adjustment and now they don't wear out so easy
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #7
I was lucky in that I had a cut off piece from a dozer cutting edge stock. (T1?)
I cut and shaped me a pair of 10 X 2 inch skids* for my 60 inch blower and guess they'll outlast the blower and for sure outlast me.
I had a look at them after some 6 seasons and still like new.
*I started with 12" and 1/2 cut and folded 1 inch at both ends followed by welding the insides of the cuts to shape a 'ski like' skid.
   / Wear strips or Hard-Facing beads to extend the life of snowblower skid shoes #8
My Lorenz 5' blower is an early model with smaller shoes (5"?) and were half wore out. I did run some weld beads on the shoes as a test. The beads will leave distinct scrape marks on the concrete that will fade by late summer. I would rather have the large flat shoes as they glide better.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
197711 (A51244)
197711 (A51244)
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
UNUSED CHERY INDUSTRIAL 9.5' WORKBENCH (A51248)
UNUSED CHERY...
