If you push my blades upward, they come very close to hitting the front edge of the hog front piece. IN fact, if I should go over a woodchuck hole, the upward movement of the blade can crease the deck of my cheapo Lowery 500. What are the chances the bolts are worn allowing more slop in the blade movement upwards toward the deck or front steel bar on the anterior part of the deck? I notice that when I grab the blade tips, I can move the blades a good 3" when I push upwards. When I bought the unit, it had the circular indented crease mark on most of the tip circumference. Is it possible to tighten the nut on the blade so there is not so much slop when moving the blade tips upward? I swear it is not some real nasty problem, just loose bolt nuts, say.
