Weakest Link
/ Weakest Link #1
hayden
Elite Member
VT
Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
Turns out it's all of them.
I rigged up my 3PH snow blower this past weekend and went throught he usual lube and inspection process and while running the blower and dripping oil on the drive chain I noticed the chain jumping every time around. I shut things down and found a link coming out.
Closer inspection of the chain reveiled about 75% of the links had fractures and failure was immenent. Needless to say I'm off the buy a new chain, but I think this speaks for the benefits of a slip clutch over a shear bolt. If only I could get the drive shaft off the gearbox shaft, I'm be able to add a clutch.
Check your drive chain - it may be the weakest link.
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
John Deere 980 28' Field Cultivator (A66285)
John Deere 980 28'...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
