Weakest Link
   / Weakest Link #1
hayden
Veteran Member
VT
Kubota L5740 cab + FEL, KX121, KX080
Turns out it's all of them.
I rigged up my 3PH snow blower this past weekend and went throught he usual lube and inspection process and while running the blower and dripping oil on the drive chain I noticed the chain jumping every time around. I shut things down and found a link coming out.
Closer inspection of the chain reveiled about 75% of the links had fractures and failure was immenent. Needless to say I'm off the buy a new chain, but I think this speaks for the benefits of a slip clutch over a shear bolt. If only I could get the drive shaft off the gearbox shaft, I'm be able to add a clutch.
Check your drive chain - it may be the weakest link.
2010 Ford Crown Victoria Sedan (A48082)
2010 Ford Crown...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2009 Chrysler 300 Sedan (A48082)
2009 Chrysler 300...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2025 12v Diesel Pump (A48081)
2025 12v Diesel...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
