Loader weak
   / weak #41
I have a DK65 with a KL1730 Loader 1300 hours. Runs great with plenty of rear hydraulic power but loader is weak. I added a bobcat quick connect adapter and now my bucket will not hold itself up let alone pick anything up. Goes up and down and then as soon as I let go it starts to drop. I am waiting for a pressure guage to test pressure but regardless will need at a minimum some kind of adjustment? No leaks. Help!!!
   / weak #42
Unplug and plug in all of the hydraulic quick disconnects . Might not fix it, but doesn't cost anything to try.
   / weak #43
Sounds like your valve you raise and lower your bucket with is leaking. When you release the handle it should go back to the center position. The center valve is leaking.
   / weak #44
Or possibly a pressure relief valve is leaking.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
