Weak FEL on 4220D
   / Weak FEL on 4220D #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I also posted this under Yanmar brand, but no response. Hope someone here has some info on this.
I have a Yanmar 4220D with V3 FEL (yeah I know Vietnam paint job rebuild, but I bought it before I discovered Tractor By Net)
I have had it a couple of years and when I first got it, the FEL had lots of lift/curl capacity. It would actually lift the rear wheels off the ground if you hung the bucket teeth under a tree root. Now it is very weak and will hardly put any pressure on the tractor even in the curl mode. The 3 ph still works as good as ever and picks up lots of load. I dont have a pressure gauge to hook on to see what pressure it is putting out. Anyone have any idea what could be wrong with this. It looks like the joystick might have some sort of setting on the side, perhaps a relieve valve or something, but I have not touched it as I am not sure what it does. It is to the far left of the handle and has a hex key adjustment with a lock nut to hold it in place. Could this thing have become weak and need adjustment?
   / Weak FEL on 4220D #2
You do need a gage to check the relief setting, and pump pressure. . You could have some crud under the relief valve not letting the pressure rise to the lift specs. Pump may be weak. That sounds like a relief valve you are describing. Valve spools worn out.
   / Weak FEL on 4220D
Thanks JJ. I got to say you look a lot younger without the beard.
This is my first experience with a FEL on a tractor and with the Vietnam rebuild / FEL installation, I am sure that they used the cheapest valve they could find although with the exception of the bucket, the valve holds up everything with no dropping. The bucket will creap down when mowing over rough ground but the lift stays put for months when parked.
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
