Wd45
mmckim90
Brashear, MO
JI Case
What kind of Diesel engine or gas engine can I put in my wd45 that isn稚 stock engine.
What kind do you want?? I've seen them with a Buick V6, a Wisconsin twin and some others in them...
WD has a frame so almost any will work, with some work...
SR
Nothing will bolt right in, pretty much any of them will work, with some work!
SR
/ Wd45
I don稚 want a huge diesel motor but one with about 80 horse.
Perkins 4-236 or 4 cylinder B series Cummins. Gonna be right much more motor than it originally had, though.
You definitely want something with a governor on it. Most diesels should have one. Automotive engines will fall on their nose, unless you find an old 6 cyl. truck engine with a gov. Or, put a belt type driven governor on it.
An adapter plate will have to be made to fit between the engine block, and your tractors clutch bell housing. Depending on what the engine is off of, the crankshaft may need to be bored, and a proper bushing inserted for the input shaft, to keep it in place. Then some sort of cross member across the front of the engine to carry it. Then comes to adapting to the original radiator, or replacing it, to be able to cool the engine properly. In the long run, if you have to have all of those pieces made, it'd be less expensive to rebuild the engine in it, with a lot less hassle.
/ Wd45
What all can I do to the engine now besides bore it to get more hp.
It's a lot of work, but I see them at shows, fairly often,
Buying a bigger tractor, IS the real solution!
SR
3268 (A63117)
3268 (A63117)
New 20' Container  (A62679)
New 20' Container...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
