WD-5 Miller Welder
   / WD-5 Miller Welder #1
Huffmang
Warm Springs VA.
1936 F-20 Farmall John Deere H 165 Massey Ferguson
I have a wd-5 miller welder that quit working. Motor still runs but won't put out curent or weld. Don't know what to check. Had to buy a new welder due the time of the June storm. lost power for 96 hours. Needed a welder to keep things going. Any ideas on what to check? Or anyone want it for 500 dollars, motor is still good.
   / WD-5 Miller Welder #2
There should be a "exciter wire" that provides excitation for the gen to put out. It might be broken, loose or fused. That's the first place I would look.
Not familiar with that welder but the wire should come from the engine 12V. look for a wire that goes from the engine to the gen.
Miller a lot of times will have a schematic on a inside panel.
Thanks will check that out.
   / WD-5 Miller Welder #4
Huffmang, I just went through this with a lincoln, I would do like Stimw said first, if that doesn't help, check for a breaker, don't know if Miller uses them but lincoln does. In my case the breaker was as if it wasn't popped but after pulling the hood and checking with a tester, that was my prob. Also you might want to check the computator for cleaning. Good luck and hope you find the prob, I know how agrivating it can be. If all else fails and you want it gone I may take you up on the sale.
This is a 78 model have not found any breakers. This unit went down on me during the 6/29/12 storm. had to get another one quick. So it is for sale. It has a herules dieasel i believe. Motor an everthing else is in working order. It weighs around 1900 hundred pounds
2024 CASE TV450B SKID STEER (A51246)
2024 CASE TV450B...
2015 Ram 3500 Crew Cab Truck (A52384)
2015 Ram 3500 Crew...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
New Holland 1745 (A50123)
New Holland 1745...
