Chipper WC8 Wood Chipper, any weakness to look for when buying a used?
   / WC8 Wood Chipper, any weakness to look for when buying a used? #11
Sorry I am kicking this old tread up, but I guess it's a better idea than to start my own.
I also living in Norway, and thinking of buying this WC-8 with mechanical feed.
@Avgv how is yours doïng after the two years you own this one?
   / WC8 Wood Chipper, any weakness to look for when buying a used? #12
come on, I suggest you buy from me, I sent a PM to you.
It works good, the feed does the job if the trees are not to wide.
I haven't a lot of hours on it but maybe 40 - 50 and I have only sharped the blades once, works great on both my quite small tractors.
So I can recommend it, the only thing i don't like are the access to the blades, a bit tight but not a big problem.
   / WC8 Wood Chipper, any weakness to look for when buying a used? #14
Thanks Agvg!
The shop that sales the WC8 here in Norway, did not recommend it because the feed. It should be no good. He advised the BX42.
I have seen several movies from both.
And indeed most movies are to proof how big trees you can chip with it. I Think everything bigger than 3 inches is firewood and will not be chips.
What I don't like at the BX42 is that the flywheel is mounted direct at the PTO. That means a lot of stress at the PTO of the tractor. Espessialy because this flywheel is not so heavy.
The WC8 has V-belts and a twice as heavy flywheel which both will dampen a lot for the PTO.
On the other hand V-belts will wear out , and are not cheap.
The feed works OK, but of course you must think when you use the chainsaw so the branches is easy to feed through the chipper.
To my use it is a very good tool
   / WC8 Wood Chipper, any weakness to look for when buying a used? #17
Tanks for the picture, that is exactly what I planned to chip. All those 'gråor' ( greyalder?) and some tops of the spruce.
I think I made my dsscion, thanks Avgv.
besides: which part of Norway do you live? I saw recent pictures with snow already ( or still from last winter )
I'm living in Namdalen - Nord Trøndelag.
The pictures are from my farm i Aurland in Sogn, I also have a property in Brandbu.
   / WC8 Wood Chipper, any weakness to look for when buying a used? #19
Those two are not close to each other!
Lot of traveling, but absolute a nice area!
No, its a 4 hours drive
John Deere M665 Zero Turn Mower (A55851)
John Deere M665...
9202 (A50322)
9202 (A50322)
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
