Ways to increase boost on 4120, 4320, etc?
   / Ways to increase boost on 4120, 4320, etc? #1
btb
Atlanta, GA
Deere 4110
Anybody know if there is a way to tweak the HP of the 4120 or 4320? Seems that since the engines in that line are all identical in size, weight, etc Deere must have added more boost to get the power. I used a tuner on my F250 6.0 Diesel to add power, so I wasn't sure if there are any inexpensive tricks to adjust the boost on these tractors?
Thanks!
   / Ways to increase boost on 4120, 4320, etc? #2
I hope sombody has an answer for this, I have been wondering the same thing since they came out.
   / Ways to increase boost on 4120, 4320, etc? #3
Its probably more likley that they use different injectors rather than changing the amount of boost.
   / Ways to increase boost on 4120, 4320, etc? #4
More power requires more fuel, but more fuel requires more boost.
Probably just installing the injector nozzles off the higher powered units would be adequate and then adjusting the wastegate pop off to accomodate the increase fuel injection with more psi of air under load.
   / Ways to increase boost on 4120, 4320, etc? #5
My understanding is that the parts are the same between two goups here.
4120/4320, and 4520/4720
So the lower model can easily be set up to the next level, and since I'm sure the upper model can also go up some, it can go even further.
As for boost, you'll have to see if there is a hose and a wastegate on the turbo. Then I'd suggest adding a gauge to see where it boosts under max load. From there a little tinkering could likely be done.
   / Ways to increase boost on 4120, 4320, etc? #6
Here's a photo of the turbo on our 4120. Not the best photo of it, but this subject wasn't in mind when I took it...
Turbo - 4120
   / Ways to increase boost on 4120, 4320, etc? #7
I'd say why bother? The frame size and weight of the tractor won't change, and unless you're doing something really tough with the tractor, I doubt you'll see much difference. After 100 pretty rough hours on my 4120, on our 40 acres I've yet to run out of power. I just ask the tractor to do what I need to do (loader work, tree hauling with the 4 in 1, bush hogging, etc.) and invariably I run out of traction or nerve before the the engine seems even close to running out of hp. I can imagine cutting a field of 3' high grass you'd get a little more speed with the extra hp, but it my case it's not often I'll be doing that.
   / Ways to increase boost on 4120, 4320, etc? #8
I'll see if there's one on the lot we are driving by and have a look-see. The Powertech looks pretty compact in design with maybe a hidden intake manifold incorporated in the valve cover???
If there is a hose coming from the compressor (hair dryer) to a mechanical plunger/canister this is a wastegate. If not, you'll have to check turbo part numbers from 4120 to 4720 and see if there is a difference.
More fuel will creat more drive and more boost all by itself. How much fuel it can stand will be dependeant on how much smoke it now makes under heavy load which I doubt is much at all...
   / Ways to increase boost on 4120, 4320, etc? #9
You're right - the intake is hidden with the rocker arm covers. From Deere's site:
FEATURES AND BENEFITS
Optimized Gear Train
Front gear train of two high-contact-ratio gears mounted to the block
Impressive low noise characteristics
Poly-vee Front Drive
Automatic belt-tensioner and 6 rib poly-vee drive belt minimizes maintenance and increases belt durability
Independent Fan Drive
Fan drive operates independently of water pump and is available in two heights to adapt to enclosures
Fan drive ratios above and below 1:1 are available to match specific application requirements
Hydraulic Valve Lifters
Automatic adjustment eliminates the need for valve-lash adjustment, contributes to lower noise levels in the valve train
Lowers operating costs
Multiple-Function Component Integration
Timing gear cover includes water pump housing, oil pump housing, governor housing and sensors
Rocker arm cover includes intake manifold
Integration results in higher quality, easier service, and reliability
Independent Water Pump
Durable cast-iron water pump resists corrosion and pitting for increased wear life
Smooth Engine Operation
Optional balancer shafts located inside the engine block with two bearings per shaft
Decreased vibration reduces operator fatigue and need for instrument and control isolation
Starting Aids
Quick acting glow plugs are standard equipment and provide exceptional cold weather starting at temperatures as low as -15 degrees Fahrenheit
Optional block heater is available
Innovative Fuel System
Contributes to cost effectiveness and clean design
Mechanically governed unit pumps mounted inside the block eliminate external high-pressure lines, minimize leak paths and reduce noise level
   / Ways to increase boost on 4120, 4320, etc? #10
OK, here's what I observed. No wastegate. Model # S1B S031 I may have a 1/I or S/5 error as it was cold and windy. This turbo was on a 4520 so let's see what model # the 4120 has...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
