Way for Two People to Tote a Battery Up and Down a Hill?
   / Way for Two People to Tote a Battery Up and Down a Hill? #11
You could put a pole between one of these battery carriers for a two person lift. Alternatively, could you leave the battery there and hook it up to a solar charger?
   / Way for Two People to Tote a Battery Up and Down a Hill? #12
My first thought would be a hand truck. Some have bigger tires then others and would travel over rough terrain a lot better. I'm not a fan of Harbor Freight, but for something like this, it might be OK. Northern Tool is a step up in quality for just a little more money.
   / Way for Two People to Tote a Battery Up and Down a Hill? #13
Check out the HF "bigfoot" hand truck - with the wide soft tires.
I think it is on sale right now for ..... $39.99 ??? (or $39.99 with a 20% coupon?)
I have 3 of them.
Might be a good idea to have the tires foam filled too.
The Bigfoot I bought a few years ago,popped out the wheel bearings the first time I used it. I owned it about 6 months before I used it,so they wouldn't take it back.
   / Way for Two People to Tote a Battery Up and Down a Hill? #14
I have a HF Bigfoot hand truck, about 20 years old. I seldom use it. The axle being higher, the load must be bigger to balance over the axle, or it takes lots of force to hold down the handle. I thought I could move smaller boulders with it but it is harder to use than their conventional sized one. Still in good shape except for some light rust.
Bruce
   / Way for Two People to Tote a Battery Up and Down a Hill? #15
Sounds like trail building time.
   / Way for Two People to Tote a Battery Up and Down a Hill? #16
Bruce
I would say that a "small" boulder would likely weigh at LOT more than most batteries.
I moved a 500+ pound pool heater with one of my Bigfoot hand trucks.
Like most everything else at HF, the Bigfoot is not superb quality, but it works, and the price is right.
For moving a battery over uneven terrain/hillside, it should be quite satisfactory.
   / Way for Two People to Tote a Battery Up and Down a Hill? #17
Why do you need to move the battery ? If it's just to charge it, get a solar charger and hope for sun. Or run a power line down to a battery charger. What about getting another battery and swapping them out at a more convenient location? I always keep another deep cycle battery around just for emergency starts, etc. Solar charger works in a day. (a SUNNY DAY). I've been powering a wireless router from one of my windmill towers to broadcast a video feed from there using a car battery. No issues with solar's ability to keep the voltage up.
   / Way for Two People to Tote a Battery Up and Down a Hill? #18
I'd recommend the Harbor Freight bigfoot hand truck as well for this task. I think I got ours for about $30 on sale with a super coupon. I bought it to remove large maple rounds from inside a fenced in yard where a tree fell and no access for tractor. Worked fine.
As someone mentioned, its axle is up a bit higher, so it can take some leverage and work to tip a load back and keep the handle from popping back to vertical. An easy way around that is to put a couple/three thicknesses of 2X6 on the platform first, then put your battery on top of that. It will raise the center of gravity enough to make tipping back the handle much easier, yet not enough to make it unstable. Find the thickness of 2X lumber that works best for you, then nail them together. Some rubber tie down straps to secure everything and off you go. :thumbsup:
700 lb. Capacity Bigfoot Hand Truck
   / Way for Two People to Tote a Battery Up and Down a Hill? #19
I also use that bigfoot hand truck with a 20# propane cylinder and weed burner torch to move easily around my yard burning weeds along the fence.
   / Way for Two People to Tote a Battery Up and Down a Hill? #20
I'd get a solar battery charger and leave the thing in the boat.
2010 FREIGHTLINER M2 106 EXTENDED CAB MECHANICS TRUCK (A56129)
2010 FREIGHTLINER...
SARLO MOWER (A55758)
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
