WaxMan's Modifications to the 2013 Grand L 3240 cab
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #91
You guys should linex your steps. The step feels so much better linexed and you don't have to worry about the paint wearing off.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #92
I am seriously considering that once I have determined mine doesn't need further modification, shortening. Mine is a bit lower than Waxman's, but seems OK so far. I have used mine a few days in the woods and in ditches without incident, but want to get some more time on it.
Your tractor is bigger then mine, I think your step is longer then on the 3240's to begin with. I cut the first step down just to keep the spacing even. Not for ground clearance.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #94
We weren't sure, so my brother just skipped that part and instead of taking the whole tractor on a road trip to his shop, he just took the step. Having bent the much higher steps on our Case CX80 and M8540 as well as my old L5030, I know I will eventually bend something. I am just hoping it doesn't happen too often and I have learned to check and make sure the step is where it shold be before dismounting.
It is probably a good thing I am not as mechanically or close to it as you or I would be modifying stuff all the time. I would really like to incorporate the step platform like our M Series on the GL. I love the feel of the much larger platform and gripping surface.
I agree I like the M steps, a nice clean look. Two steps are better then one either way.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #96
Ditto the Linex… i often slip on the edge of my BX floor edge where the mat does not cover. Even when dry. I am sure the steps are not as bad though and the Linex is tough as well as providing grip.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #97
waxman you do some nice work. i like the idea of a camera but the way i use mine i would break it.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #98
If you haven't done so already, check out some of the threads by ovrszd, 4shorts and 94BULLITT, can't think of the others off hand.
   / WaxMan's Modifications to the 2013 Grand L 3240 cab #99
Your posts are great Waxman. Many cool ideas!
I'm preparing to install an Agcam system with two cameras with the 9" monitor. (Your front bucket setup looks super.) Initially I will just mount the front camera on top of the cab on my L6060 similar to the way 4Short has done --- but I hope I can figure out how to fabricate a tube like your did.
I also noticed your nifty monitor screen shade. Is that an option you got from Dakota Micro or from another source? Maybe there are generic shades for 9" video monitors?
I also hope to copy your second step idea!
Keep up the mods! And thanks again...
Ed
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
