GaryBDavis
I, uh, used my tractor to dig the holes to plant these trees. So there's the required tractor involvement.
The tank is 50 gallon and I purchase it down at the local ag sprayer equipment dealer. I like to buy from these guys because they have everything you can imagine and the tanks come with no holes so you can locate and drill your own.
The drain hose is 1" with a cut off valve about 2' from the end of the hose. The inlet for filling the tank is 1/2" with a check valve and garden hose adapter. The check valve keeps water from sloshing out when you drive around, prevents flow back into the garden hose and acts as an extra air inlet when letting the water out.
I pour water into 5 gallon buckets that have a single 1/4" hole drilled in the bottom. This lets the water out slowly which, as we all know, is the proper way to water a tree.
I was pretty pleased with the flow volume. I can fill a bucket just about as fast as I can with a garden hose.
This set up would work well in the FEL of my tractor. I could lift it up to get even more water pressure and a good, strong flow, but it works like it is.
