Watering lawn in a remote location?
   / Watering lawn in a remote location? #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
I was hoping someone might have a few ideas.
Long story short - I need to establish some grass to avoid erosion problems on my property that is a bit far from my house. I couldn't get grass to establish well enough last year and the lack of water had part to do with it.
I could run several hundred feet of hose out to the area from the house and water from my well. If I go this route, I think I'd have to purchase a bulk roll of "tubing" and use it as a garden hose.
OR
The area is right next to my pond. The problem is that I do not have electric out there and my generator is bolted next to the house. I have a 12V pump but it isn't a continuous duty to handle a ton of water. Even if I had a pump to handle the volume, connecting a sump pump (for example) to a garden hose with a sprinkler seems like a bad idea since the pump will be trying to move more water than the sprinkler puts out.
Not sure what to do. Thought about an IBC tote and gravity watering, but then I'd have to go buy a tote (or luck out and find one that's actually clean), a pump, a way to power a pump....etc etc.
   / Watering lawn in a remote location? #2
Is this a temporary or permanent situation? Once the grass is established do you plan to continue watering?
Temporary.
My friend (an agronomist) said as long as I could water for 2 weeks, daily, he should be able to get everything established (the soil is not good - old fill dirt).
However if I can see the need kill the existing grass in a few locations where the slope is very high. ODOT has a blend of brass see for "high slope, low growth" so hopefully I don't have to mow those slopes again. Just spray for weeds.
I could buy 4 - 6 100' sections of garden hose, but I'm not sure how much pressure drop I would have. Or run 500' of PEX out.
   / Watering lawn in a remote location? #4
OR
Little 3hp gas engine (may have been a 5hp) and a pump from a pump supply house. They will advise on the pump type to suit the application. That is what I used for several years to water out of a small creek. House supply didn't have enough pressure to run sprinklers.
Later:
ooops you probably don't have a convenient creek or pond.
   / Watering lawn in a remote location? #5
It is terrible time to start grass in Ohio. You will need to water for at least a month. For remote location, I have used 500' of 3/4" hose with decent pressure. How large of area are you trying to grow grass?
   / Watering lawn in a remote location? #6
OR
Poly pipe is probably a lot cheaper than a pump, tote, power source, etc....
How's your soil? I ran a hundred feet of poly pipe underground out to my garden many years ago. I just dug a hole by the house, attached the poly pipe to a plow share that I bolted vertically to a support, slipped it 8" into the hole, and drove out to the garden. I was shocked at how easy it pulled in our sandy soil. It was so easy, that after I was done, I wanted to see how tight it was. I grabbed the pipe at the end and was able to easily pull it with just my arms. So if you don't have too many curves and can make straight runs, I'd suggest that over getting a pump, tank, power source, etc...
   / Watering lawn in a remote location? #8
A little 12v submerged pump in the pond is how I’d do it if it was more than about 500’. Under that and I’d do the flex hoses- Amazon has several.
We water all of our juvenile plants with the hoses. Not ideal with regards to speed but it works for a temporary solution. I put a splitter near the end so two of us can water at the same time.
   / Watering lawn in a remote location? #9
I use a roller pump on my little Kubota BX2200 PTO to water my pasture. You then get a rolling hose cart and a good sprinkler. Here's the one's I bought. Works like a champ. For the suction side of the pump, I use a suction hose and an inlet filter from Tractor supply. I wrapped my inlet filter with a couple of layers of some shade cloth netting I had lying around to make it even more debris proof. I just back the tractor up to the waters edge, set the brake and put two wheel chocks down to be safe. (just because I'm paranoid doesn't mean they're not really out to get me :laughing:)
Here's some links:
Northern Tool Wheeled sprinkler
Northern Tool hose cart
TSC Suction hose
TSC Basket Strainer
TSC Roller pump
I actually have both a 4 roller and an 8 roller pump, but the 4 roller seems to work fine. I don't recall what diameter suction hose I bought, but I think it's 1 inch, maybe it's bigger.
   / Watering lawn in a remote location? #10
A couple of years ago I bought a 500' roll of 1/2" poly pipe to get some grass established in my drive. I cut it into 4 pieces and bought male and female hose repair ends and pressed them in to make the pieces more manageable. Had to heat the tube a little but not too much to get the hose ends to go in. My well would only support one sprinkler at a time so I had to do a fair amount of monitoring and moving. I stuck a 360 degree sprinkler head on an old light tripod and just kept moving it to get full coverage. I had less than a hundred bucks in it.
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
New/Unused AGROTK YC-26G Sawmill (A54865)
New/Unused AGROTK...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
