Water Well Drilling
/ Water Well Drilling #1
Bigtoe1
I would like to drill a water well to be used for livestock and watering the lawn. I have looked at the Hydra-Drill but this a bit expensive.Would like to drill one by hand .Any ideas?
I live in Texas and the soil is sandy.
Bigtoe
/ Water Well Drilling #2
We use a hand auger to drill wells around here in sandy soil. If it's really sandy you'll need to sink a casing with it. Take a look at the following site for the kind of auger we use. http://www.globaldrilsup.com/
If you're decent at welding you can buy a mobile home ty-down anchor and weld a 1" pipe coupling to the rod and a short piece of 3-1/2" thinwall pipe to the top of the flight to make your own auger then just use lengths of pipe to screw it into the ground. If you'll look on page 5 of this document you'll see an example of what the final product will look like. Shallow Well Drill Sets
/ Water Well Drilling #3
Hi
I hope this make sense, please forgive me if it does not.
I have put down several bores to about 36 feet in clay useing a home made tool and mains water.
This is done using lenghts of 3/4 water pipe
First pipe has an arrow welded on the end in such a manner to allow water to squirt towards the arrow head.
The top of the pipe has a snap lock garden hose fiting attached so you can connect the garden hose.
Use a wooden handle that clamps around the pipe so you can turn the pipe and arrow, the water assists with the boreing and washes the loosened material to the surfuce. as you go down just keep adding lenghts of pipe, (10 feet is suffice )
Always turn in a clockwise direction so your joins don't undone
/ Water Well Drilling #4
We call that jetting a well down here and it works really well where you have a supply of water to begin with. We've also used a gasoline driven pump to supply the pressure if it's close to a pond, creek or other source.
/ Water Well Drilling #5
A lot of people around here drive them with a tool that is just about like a T post driver only it is big enough to fit over 1 1/4 pipe. Its normally just used for lawn watering and only about 25 feet or less deep. They use 5 foot lengths of pipe with a well point at the tip and a heavey screw on cap at the top. As it goes down they add a length of pipe and move the cap up to the top of the next joint of pipe. This in the Rio Grande Valley
/ Water Well Drilling #7
Hello BigToe. I looked into one of those units. Our well, professionally drilled to 240 feet, was much less expensive than buying one of those rigs. Of course, the sales literature says you can then sell the unit and recoup some of your initial outlay. (Or, you can read that backwards, and go look for someone else selling their used unit. You could even benefit from their experience, unless they were not successful and are just trying to recoup THEIR loss!) Our driller had lots of sand until he hit lots of rock.
/ Water Well Drilling #8
Can be expensive...............
We just had an irrigation well dug. The driller used a 40HP tractor and manufactured rig to dig a 6+ inch hole
about 60 ft. Worked fine, he sunk the casing and we now have cheaper lawn water.
BUT, he told me the week before, he broke the auger off and lost about 30FT of auger and the bit. No choice
for him but to buy more, move over a couple feet and start over....................... Don't think he made any
money that day--and he said his insurance was like $1200 a month............
A lot of work to do it commercially, a lot of investment, and working hard for every dollar he earns!
Take Care,
Ron
/ Water Well Drilling #9
Hearne, TX? I built my own version of a Hydradrill. Earthquake auger, vertical frame and 3/4" black pipe for drill tool. /forums/images/graemlins/shocked.gif
/ Water Well Drilling #10
I've driven a point for a hand pump(drill point with 1 1/2" pipe) by hand. A lot of work bt hit water about 25 feet or so. Trouble is driving a point and if ya hit stone its he almost impossible to back it out even turning it. Took me half a day getting one out when my FIL hit rock doing his.
I'd like to see that homebuilt version of hydrodrill.
/ Water Well Drilling #12
Thats a pretty neat tool. I was reading the discription and could not figure out why you needed a trench to drill a well /forums/images/graemlins/crazy.gif. Oh, I get it now /forums/images/graemlins/laugh.gif. Should have read the rest of your post /forums/images/graemlins/tongue.gif Bits are pretty resonalble and total cost is not too bad.
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
1761 (A58375)
1761 (A58375)
Dewalt DW505 Hammer Drill (A60353)
Dewalt DW505...
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
