Traction Water weight in wheels
   / Water weight in wheels #1
John Weaver
Georgia
2000 JD 790
I have a JD790 and have gotten several nails in the front tires. Plugs don't have a good success rate. I am thinking of installing tubes and filling with water. The tires are Tital Trac Loader R4 25X8.50-14. Any thoughts? John
   / Water weight in wheels #2
The water won't help getting stuck with more nails. Just needing weight?
I just took delivery on two Titan tires that size. Wore the tread off and never had an air issue. Guess I was lucky.
   / Water weight in wheels #3
Get some tire seal. And not that slime. JD makes some, don't really care for it. It is a little slimy. (I also saw several dealers online trying to dump it ) I use some stuff from Schaeffer's, works good and has several other uses, like trailer tires, camper tires, 4 wheelers, etc. Pretty much anything that isn't balanced. You can also add enough for balance if desired. Washes out with water unlike slime.
   / Water weight in wheels #4
you could foam them.. otherwise, if ina nail / thorn area.. I sure would not tube them.. i'd plug them, then add slime or similar..
2017 Dodge Journey SUV (A51694)
2017 Dodge Journey...
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2023 LMC H40024 LOT NUMBER 189 (A53084)
2023 LMC H40024...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
