water temperature gauge
   / water temperature gauge #1
msjanket
Is there a pre-tapped hole for a water temperature gauge on the Mitsubishi K3a engine? Is it there already?
   / water temperature gauge #2
I put one on mine recently. There is a plug on the water pump snoot for the top radiator hose so you don't have to use the one for the light. It was very tight, probably had locktite in it. It was an allen plug, I think 1/4 inch. The sender bulb has to be where there is flow.
   / water temperature gauge #3
Correction, that water pump snoot goes to the bottom radiator hose.
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
