OP
        GrandJack88
- Joined
- Oct 18, 2021
- Messages
- 6
- Tractor
- Jioti DK 35 2004
Thanks for info, not always good here with a voltmeter!!!Many of those gauges are similar.
Full voltage = full scale.
The sender is usually nothing but a wire wound variable resistor and activated by a float for fuel
or a thermistor for heat.
Circuitry is as simple as + voltage and a ground.
Always make sure grounds and connectors are good.
A volt/ohm meter is your friend.
Having discected my share of gauges I was surprised to note that often the gauge guts are the same be it temp, fuel and even RPM. Often just different faces.
