Water pumps for sprayer? (internal bypass)
   / Water pumps for sprayer? (internal bypass) #1
Blagadan
Western Europe
Kubota B7100D
Does anyone know what the advantages are of having an internal bypass valve on a sprayer pump?
thanks,
b
   / Water pumps for sprayer? (internal bypass) #2
thanks,
b
Yes. with a sprayer if the pressure builds up in the pump while the sprayer is not being used the excess fluid build-up will be used to aggitate the sprayer tank by dumping it back in the tank!;)
   / Water pumps for sprayer? (internal bypass) #3
Doesn't it also help allow you to regulate your pressure, ie: the more you turn the valve to bypass the less pressure on your hose???
PumpJack Brand Pump Jack (A55218)
PumpJack Brand...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
1275 (A50490)
1275 (A50490)
