Water pumps for sprayer? (internal bypass)
   / Water pumps for sprayer? (internal bypass) #1
Blagadan
Western Europe
Kubota B7100D
Does anyone know what the advantages are of having an internal bypass valve on a sprayer pump?
thanks,
b
   / Water pumps for sprayer? (internal bypass) #2
thanks,
b
Yes. with a sprayer if the pressure builds up in the pump while the sprayer is not being used the excess fluid build-up will be used to aggitate the sprayer tank by dumping it back in the tank!;)
   / Water pumps for sprayer? (internal bypass) #3
Doesn't it also help allow you to regulate your pressure, ie: the more you turn the valve to bypass the less pressure on your hose???
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
