Water Pump Leak on '81 Satoh S-630 Bull
   / Water Pump Leak on '81 Satoh S-630 Bull #1
Lane
Only while the cooling system is pressurized does a small leak appear from the water pump. It is hard to tell if it is from the shaft seal or gasket area. Anyhow, a pump rebuild / replacement may be in order. Any ideas to pinpoint the cause and locate parts would be great and much appreciated.
   / Water Pump Leak on '81 Satoh S-630 Bull #2
I can supply a replacement if you need it. Call toll free 1-800-609-5110 or email me at satohparts.com. Bill
   / Water Pump Leak on '81 Satoh S-630 Bull #3
Check the hose first. Water pump usually leaks when cold it it is the shaft seal and leakes from a weep hole under the shaft. presure leak indicates a hose, gasket or a cracked housing. Most likely a hose.
Thanks Bill and Norm. I'll check it out.
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
TORO Z MASTER ZERO TURN MOWER (A51247)
TORO Z MASTER ZERO...
City of St Petersburg (E810) Boat 14 ft 14ft trailer (A51694)
City of St...
UNUSED WOLVERINE PFF1-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
