Water Pump Leak on '81 Satoh S-630 Bull
   / Water Pump Leak on '81 Satoh S-630 Bull #1
Lane
Bronze Member
Only while the cooling system is pressurized does a small leak appear from the water pump. It is hard to tell if it is from the shaft seal or gasket area. Anyhow, a pump rebuild / replacement may be in order. Any ideas to pinpoint the cause and locate parts would be great and much appreciated.
   / Water Pump Leak on '81 Satoh S-630 Bull #2
I can supply a replacement if you need it. Call toll free 1-800-609-5110 or email me at satohparts.com. Bill
   / Water Pump Leak on '81 Satoh S-630 Bull #3
Check the hose first. Water pump usually leaks when cold it it is the shaft seal and leakes from a weep hole under the shaft. presure leak indicates a hose, gasket or a cracked housing. Most likely a hose.
Thanks Bill and Norm. I'll check it out.
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
RoGator RG1100C (A53473)
RoGator RG1100C...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2004 Ford F-550 Wrecker Truck (A51692)
2004 Ford F-550...
2019 AMADAS SPC-6 LOT IDENTIFIER 231 (A53084)
2019 AMADAS SPC-6...
