Water Pump Gasket
/ Water Pump Gasket #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Howdi. I will need at least a Gasket for my Water Pump. Iseki TA247 27hp? Approx 1992. 3 cyl Diesel. Can anyone point me in the right direction?:confused:
Much appreciated.
MM.
/ Water Pump Gasket #2
Hello again. You can buy stock gasket material from an auto supply. A ball peen hammer will cut out a gasket by putting the material over the engine side of you pump and tapping around it with the hammer. If it is your first time, a little extra material might give you a practice or two.
/ Water Pump Gasket
Thanks.. I have Gasket material..I would do that if need be. Not too bad of a job actually.. Thanks again..
MM. >
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
