Water Pump Gasket
   / Water Pump Gasket #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Howdi. I will need at least a Gasket for my Water Pump. Iseki TA247 27hp? Approx 1992. 3 cyl Diesel. Can anyone point me in the right direction?:confused:
Much appreciated.
MM.
   / Water Pump Gasket #2
Hello again. You can buy stock gasket material from an auto supply. A ball peen hammer will cut out a gasket by putting the material over the engine side of you pump and tapping around it with the hammer. If it is your first time, a little extra material might give you a practice or two.
   / Water Pump Gasket
Thanks.. I have Gasket material..I would do that if need be. Not too bad of a job actually.. Thanks again..
MM. >
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
