Water pump for 1602D
   / Water pump for 1602D #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
I think that the JD 755 uses the same 3T75 engine as my 1602D. Does anyone know if I could just use a 755 water pump on my 1602?
I don't like having to change the antifreeze ratio for summer and winter use, its just asking for me to make a mistake.
Can't say for sure but they look different to me. Yanmar Tractor Parts: WATER PUMP _ http://www.wengers.com/Parts/ImageDisplay.ashx?i=P0045363&itemclasscode=AH The 2nd one is from Wengers with john deere part #EPC200687/R
That's interesting. On my 1602D, it looks like a water pump, but I'm sure I've read it was a thermosyphon setup. I just assumed it was a cowl designed for the thermosyphon setup, with a shaft and bearing up front for the fan pulley. I didn't want to pull it apart, in case I damaged the gasket....
Does anybody know for sure, without me pulling mine apart?
   / Water pump for 1602D #5
It may be like my 1510 in that it has a pump but does not have a thermostat.
Mike
   / Water pump for 1602D #6
My buddy's 1610D has a water pump same one thats listed for a 1602 dont know about a t-stat.
   / Water pump for 1602D #7
The 1602 has a water pump but no thermostat.
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
