water pipe installation advice
   / water pipe installation advice #11
stumpfield said:
Is there any special connection/design I have to consider and be aware of? or it's just as simple as trench and bury the pipe along the road like typical sprinkler pipe installations??? any advice is greatly appreciated.
I think 18" deep for the pipe is National Plumbing Code... Power is that way too. Check with a local plumbing house to be sure?
That is the minimum, but deeper may be required for frost line etc.
   / water pipe installation advice #12
Before glueing , always, always use pvc cleaner solvent for a good bond. I would recomend burying it and using premium backfill ( sand) I have seen rocks cut pvc pipe if a truck or anything heavy drives over it. Check for leaks before burying it ( murphy's law) . You may want to "tee" a few sections for future tap in if needed.
Engel 20' Boat (A50121)
Engel 20' Boat...
2016 Chevrolet Malibu Sedan (A55758)
2016 Chevrolet...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
2013 UTILITY VS2DX DRY VAN TRAILER (A54607)
2013 UTILITY VS2DX...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
