Water Leak 3 cyl. 2301
   / Water Leak 3 cyl. 2301 #1
2 Acre Farm
I had to add water twice in three weeks, got looking for leak and found
what appears to be a coolant seep from left side of block,1 to 2 inches
below freeze plugs. Kind of hid behind starter. I'm thinking this is pretty
serious. Any idea's?
   / Water Leak 3 cyl. 2301 #2
Typical location for a crack in the block. There's only one sure fix, and that's a weld.
   / Water Leak 3 cyl. 2301 #3
I would make absolutely sure it's not a freeze plug.
   / Water Leak 3 cyl. 2301 #4
Like Norm said, be sure it's not the freeze plug. Since the leak is so close to one I would double and tripple check it before I condem the block. The first thing I would do is add a couple drops of some very bright food coloring dye to the coolant. Run the engine until hot and let it cool down. Remove the starter and inspect for the leak. It should be much easier to see exactly where the leak is coming from with the dye in the coolant. Ideally you would use a UV dye and a UV light but the food coloring works great in a pinch just like candle wax dye works great in oil.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
2025 MAX BUILT 82" X 20' TRAILER (A51247)
2025 MAX BUILT 82"...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51248)
UNUSED TOPCAT...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
