Water in the clutch housing ? ....B7500hst
   / Water in the clutch housing ? ....B7500hst #1
Anonymous Poster
Epic Contributor
The owners manual shows a drain plug in the bottom of the clutch housing, for draining water after operating tractor in the rain or washing. These tractors sit on the dealers lots for weeks sometimes, before being sold. This spring has been very wet, to say the least. Has anyone ever checked that drain plug ? Did you get any water from it ? Thanks !
   / Water in the clutch housing ? ....B7500hst #2
I did check the one on my B2710 at least a couple of times; no water ever found.
   / Water in the clutch housing ? ....B7500hst #3
Does anyone have a picture of exactly where this bolt is? I have a B2410 w/ a FEL. I was looking today and think I may have found the bolt but am unsure. The bolt that I think it may be was brighter? (not the dull gray) color and was 12 mm. If anyone has a picture, please post it. I will try to post a picture of the bolt that I am talking about too.
Thanks,
Steve
   / Water in the clutch housing ? ....B7500hst #4
Steve-
Here's a scan from the operator's manual for my B7800.
   / Water in the clutch housing ? ....B7500hst #5
The scan said it all. " Cut and dry." No Pun intended..
   / Water in the clutch housing ? ....B7500hst #6
herringchoker,
Thanks for the scanned image. My operators manual has the same photo. My problem was, it didn't seem to obvious to me when I was laying on the ground looking around for the drain bolt as to which one it was. Like I mentioned previously, I saw one bolt that looked different from the others, almost as to say "Hey look at me you idiot!!". :)
Thank you,
Steve
   / Water in the clutch housing ? ....B7500hst #7
For what it's worth, I took the bolt out that I saw looked different but nothing came out (more importantly, nothing fell apart).
   / Water in the clutch housing ? ....B7500hst #8
On some tractors, like my L4400, there is a little button you push in to see if there is water inside. Its a nice feature but the little button/pin looks very delicate. I'm surprised I haven't scrubbed it off on something.
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
INSPECTION (A51573)
INSPECTION (A51573)
