Water in my fluids, and where to get a hydraulic screen....
   / Water in my fluids, and where to get a hydraulic screen.... #1
Stokes
Kitsap Peninsula, WA
Hey Guys,
I recently bought a old 1300D. It's one step away from being a basket case.
All the fluids in this thing look the same... milky white. I've flushed out the cooling system. I've also drained out the engine oil, replacing it and the oil filter.
I've since moved into the rear hydraulics, where I've found over 2.5 gallons of milky fluid and my hydraulic return screen plugged up. There is actually a tear in my screen, and I'm in need of a new one. Any ideas on where I can source this? Also, I need an upper radiator hose. Thanks!!
   / Water in my fluids, and where to get a hydraulic screen.... #2
Hoye tractor has the screen but its used. You can also try fredericks too. Good luck with the tractor. You might need to change the hydralic fluid a few times to get all the crud and water out.
   / Water in my fluids, and where to get a hydraulic screen.... #3
   / Water in my fluids, and where to get a hydraulic screen.... #4
If the tear in the old screen isn't too bad you might be able to repair it by soldering - that's how the seams are sealed in a replacement screen.
Has anyone done business with jeepsea . com? It's good to see a supplier for genuine parts. Since their home page is .il (******) the cost of shipping might be substantial.
   / Water in my fluids, and where to get a hydraulic screen.... #5
I was going to say hoye too, they have about everything and there first class, I would order it all from them when you get your list togeather. They are about the cheapest to as well.
   / Water in my fluids, and where to get a hydraulic screen.... #6
I have the same tractor and I could't find one so I sealed the tear with JB weld. Don't forget to pull the drain plugs on the bottom of the reduction gear housing under the ales. my water was coming from the missing gear shift boot. Good little tractor for me.
   / Water in my fluids, and where to get a hydraulic screen.... #7
Good luck getting them to answer an e-mail. I e-mailed them about 6-10 times about that drop down box shift rod. Never got an answer
When I go to the auto parts store, I can find hoses that are the rough shape, but the wrong diameter. Anyone got an idea on what diameter hose this is and where I might get some? Even one of those universals would be nice.
   / Water in my fluids, and where to get a hydraulic screen.... #10
When I bought my Ym2000 from the looks of it's Hyd.Filter Screen. that was what looked to be done to mine. Someone just used Solder at the Seam. I replaced it though considering I was getting up a Parts, New/Used Groc. list and headed to the Largest Yanmar Importer for Tiller. Come to think about it:confused2: I UPS old Filter it to someone on here Yrs. Ago!!! Never heard anything from it so IMO. no news is good news. And if there was a prob. Most likely your Hear about it.:laughing:
2022 BOBCAT T64 R-SERIES SKID STEER (A51246)
2022 BOBCAT T64...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
