Oil & Fuel Water in hydraulic fluid???
   / Water in hydraulic fluid???
Thank you everybody for your replies. I feel OH SO MUCH better prepared. I'll post after the weekend on how I do. Wish me luck.
Hi Everyone,
The change out of the oil went smoothly (mostly) with the help of a friend that's done it before. The local municipal garage burns the used oil in their furnace which is pretty neat. The one thing I have to be careful of in the future is how hard the drain plugs were tightened. I can't understand why someone would do that. I really had to pull hard and I was in danger of having the socket come off the nut and take some metal with it. In any case the TC-30 has a nice warm tummy full of new (expensive -- ouch) hydraulic oil.
Thanks again for everyone's help.
Ken
   / Water in hydraulic fluid??? #13
some people don't understand what seals a particular fastener.. whether it is oring, washer, or thread deforemation, and just over tightens it to be sure :(
Hi soundguy,
Yeah, I just ordered two replacement plugs and washers. I don't want to be on my back when it's 0 degrees with a wrench trying to get partially stripped bolts off.
Ken
   / Water in hydraulic fluid??? #15
on some of these fords I work on.. they have a big bung drain.. like 2" opening.. new gasket is cheap.. or you can make one from thin 1-ply cardboard or postrer board, card stick.. shoebox.. etc. for free.
most people are so cheap they either use a glue/goo that hardens like cement, or just opt to tighten it to 50 bajillon foot pounds to seal it.
I broke the cast iron plug on my NAA taking it out due to that.
also.. they are too cheap to smear some ptfe paste on a pipe plug when re inserting it into a casting.
I ALMOST ALWAYS put in new plugs when I repalce a drain plug.
many hardware stores sell them by the pound.. or you can get 2-4 for a buck!
not worth stripping a casting or breaking a plug off or having a leak because someone was too cheap to repalce a plug.
In bad areas or thin castings.. i will even use brass plugs for safety.
I'm also not a fan of inverted head plugs.. allen or square.
for originality I always save oem inverted plugs and put ina baggie in the tool box in case I ever show one.. but for use.. i put in a new square external head plug..
have simply drilled out and re-tapped way to many broke out plgs to do otherwise.
soundguy
   / Water in hydraulic fluid??? #16
speaking of drilling out plugs.. there's a good trick hidden in that statement.
many times I have seen a stripped hole ina casting that I did not want to or could not oversize the hole due to other factors. and I would drill for the next size up pipe plug, install and lock in with thread locker, cut head off with a sawsall, and then drill and tap OEM hole size.
the cast drills and taps easy, AND if in a casting.. you are back to about the same strength and metal as the sourounding material. no heli coil to back out or loosen up.. etc. seals good too.. sometimes I've seen heli coils not seal well, for places that had fluid pressure behind them.
soundguy
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 International MV607 26ft Reefer Box Truck (A56858)
2020 International...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
