Oil & Fuel Water in fuel
   / Water in fuel #1
edmartin
Bronze Member
SC, USA
Yanmar YM2000
Does anyone have any knowledge or method for removing water from diesel fuel other than buying a large capacity tank and filter. I've tried all the local outlets using "red" fuel and get water in all of them.
   / Water in fuel #2
The fuel will float on top of the water if it is not agitated. I would let stand, siphon the top layer of fuel and separate from the original container. I would only do this if this is allot of fresh fuel that is slightly contaminated.
Mark
   / Water in fuel #4
Any container with a spigot on the bottom will drain off the water if allowed to sit long enough. I use a 55 gal. drum and pump off the top.
   / Water in fuel #5
My last load of fuel from a big supplier was loaded with water.
I use power service as well as biocides for tank treatments.
My suggestion is to have a water drain tap at the lowest point of the tank if you do bulk storage, and use a filtered breather as oposed to an 'open' tank breather.
For in the can / in tank water.. if it is a large amount, I'd crack a fuel line and purge it.
Many tractors have both sediment bowls with water dains, and some even have fuel filters with water drains... make use of them.. often!
Soundguy
   / Water in fuel #6
I find it easiest to syphon off the water. use a steel tube (3/8' line) to get to the bottom of the tank, with a rubber hose attached to that. Tip the tank a little if necessary. Just run the syphon until you get clear diesel, and you're back in business. Add a little gas line antifreeze for insurance if you like.
Richard.
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
Graco Line Lazer 3400 Paint Striper (A52384)
Graco Line Lazer...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
