scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,498
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
OK lets start here,
I built the house in 1983, three bedroom saltbox. The foundation size is 34x34. I installed foundation drains around the perimeter of my home. All was well for the first few years. Then for some reason, I believe because the bilco door precast unit on the backside of the house was not backfilled properly, the foundation drains became plugged up with dirt. Then I started to have trouble. I then installed a 2ft diameter 2ft long drain tile and installed a sump pump. When it rains real hard and the ground is saturated I still get puddles of water on the other side of tyhe basement and on the backside of the basement.
My thought at this point, would be to chisel up the basement floor around the perimeter of the basement and install drainage pipe and feed it over to the sump pump.
I would welcome any suggestions or helpful input.
Thanks
scotty
Thanks
scotty
