WTM
Has anyone actually tried to use the water drain on the bottom of the tank of a E-350DI. Do you compltely remove the plug and then try to re-install with fuel running down your arm or is there an easier way. Also, if you use clean fuel and keep the tank full, how often does this need to be done?
