water contamination on hydraulic fluid on 6900 john deere 1997
   / water contamination on hydraulic fluid on 6900 john deere 1997 #11
Hello, did you manage to solve the problem? I have the same problem and I can't deal with it, water in oil.(even the same tractor model). I would be very grateful if you could suggest something
   / water contamination on hydraulic fluid on 6900 john deere 1997 #12
Welcome to this forum
Be sure hyd reservoir breather is open IE not clogged so when hyd oil is heated to operating temp moisture can escape through open breather hole. When hyd oil is cool loosen trans drain plug a few rounds so if any water is at bottom of trans case it can leak out around threads of reservoir drain plug.
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
