Here's my secret for eliminating wasps and hornets.
For several years we paid a local exterminator to free us from wasps and hornets. Every time we called it cost us $85.00 to $110.00 depending on how many nests that we had under our deck.
I was talking with the guy that was spraying our deck on one of the visits and he was mixing a batch of the chemical in the back of his van that he was getting ready to spray. The chemical that he was getting ready to use was called Cynoff EC.
So I searched the web and located the very same chemical that he was using at the time. The information that I found on Cynoff EC was that the active ingredient that it used was Cypermethrin. The odorless, general-purpose insecticide contains the best active ingredient for elimination of German roaches, wasps, hornets, ants and other insect pests. Leaves no visible residue and the residual effect lasts for months. The recommended mixing rate was 1/2 ounce per gallon, each quart makes 64 gallons.
So I purchased a quart to try it for myself. Now, I normally mix up a gallon of the chemical using 1 ounce of Cynoff EC per gallon of water. I apply it with a pump-up sprayer and hit all the shutters, the soffetts, and under the deck. If I see a nest anywhere else I soak it down. Any insects that get hit with it quickly die and those that come back to a nest that has been sprayed quickly die. I don't need to re-spray for a couple of months after the initial application.
The last time that I purchased a quart of Cynoff EC was 3 years ago and it cost me then $80 for a quart. I still have over half left and I have saved lots of money over using the exterminator that we used to call once or twice a season. /forums/images/graemlins/grin.gif
Here is a link where I found the chemical.
Cynoff EC
Try it, you might like it! We do.....
