Washer wants to walk out of the house
   / Washer wants to walk out of the house #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Need some assistance from those of you more familiar with washing machines.
A few days back my wife complained that our clothes washer started making more noise on the spin cycle and my first thoughts were merely an unbalanced load so I didn't give it much thought.
This morning the machine got my attention so I lifted the lid. The load was not what I would consider large and there were no items in the washer that were bulkier than the rest so I believe it to be the washer at this point.
This is a Frigidare FWS645GFS2 serial XC91971121 if that makes any difference at all. I pulled the front off the washer and ran it through a spin cycle without anything in the machine. I see that the whole mechanism moves freely on a floating base and that there are three sets of tensioning springs that I would imagine keep the whole mechanism centered as it spins yet still allows movement.
The transmission appears to be cast iron and sits just above the motor assembly. The entire transmission rotates at the same RPM when the unit is in the spin cycle. I do notice a slight vibration from the tub even when the washer is empty on spin cycle. I'm wondering if these springs ever loose some of their tension and might this be the problem?
How about it, is it time to call the service tech or should I just get a bigger hammer from the pole barn? /forums/images/graemlins/grin.gif
   / Washer wants to walk out of the house #2
I wonder if you have a bearing wearing out allowing side to side shifting of the shaft or something like that? How old is the machine?
   / Washer wants to walk out of the house #3
We had a cheapo Admiral from Home Depot that started doing that after 6 months, after 1 year it was intolerable. The internals looked similar to your picture. We tossed it and bought a Kenmore front loader on closeout from Sears 3 months ago and so far, its been great. No more top loaders for us.
   / Washer wants to walk out of the house #5
Mike
If everything looks good then sassafraspete suggestion is the first one to really look at make sure it is level and still on solid ground. I have seen problems if they set it is set in a catch pan.
   / Washer wants to walk out of the house #6
Pineridge, I think some washers have a self leveling feature where you raise the back of the machine off the floor and let it back down. It is supposed to level the front of the machine to the back.
   / Washer wants to walk out of the house #7
</font><font color="blue" class="small">( all the feet down....eg is it staying level front to back, side to side )</font>
That, and an unbalanced load, are the only two problems I've encountered.
   / Washer wants to walk out of the house #8
Pine, you might also try putting the shock collar back on the lovely Mrs. Pineridge and send her to the laundrymat.
   / Washer wants to walk out of the house #9
I don't know if its like my GE, but at the top of the tub, there are ( 4 ) 'dogbone' style rubber restraint straps that kinda hold the top of the outer tub in a center position. They bolt up to the frame of the rig and screw to the outer tub. When one breaks, the load wobbles until a second one breaks, then it's all over the place.
Have a look up top.
   / Washer wants to walk out of the house #10
On ours, the front feet were adjustable, the rear feet were self-leveling. I kept the machine level and all feet were solidly on the floor, it just kept going out of balance, no matter how small the load. Really frustrating. In the end, junking it was putting a headache to rest.
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
1837 (A51248)
1837 (A51248)
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
