Washer Fluid?
   / Washer Fluid? #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
Any concerns with using washer fluid as ballast?
RimGuard isn't available within an hour or more of me...despite what their advertisement has you believe...
I can get bulk washer fluid from a company a mile down the road....probably better than nothing - unless I'm not aware of a risk with that?
Should I have tubes added or not necessary?
   / Washer Fluid? #3
Never used it in a tractor, but I did use washer fluid to load the rear tires in my rider mower. Just used the -20 stuff you get at Walmart. Been 10 years or so and no problems.
   / Washer Fluid? #4
Any concerns with using washer fluid ??
No... I did a DIY install of 25% antifreeze and 75% washer fluid.. The anti freeze used because of our growing zone 2 winter temps..
This mix is not as heavy as other alternatives, but much more available, cheaper materials and not hard to DIY install... Just some what time consuming to do..
   / Washer Fluid? #5
Same here.
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2008 John Deere TX 4X2 Gator (A50121)
2008 John Deere TX...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
