Washed Limestone as top dressing for roadbase in Central Texas?
   / Washed Limestone as top dressing for roadbase in Central Texas? #1
ustmd
Platinum Member
Manor, TX (outside of Austin)
Kioti CK27 HST
As almost everyone else here, I have a "dirt road"-i.e. graded with road base.
I am doing spring road maintenance and using a new supplier for my base said that he can get me 1 1/2 wash limestone as a top dressing for the base. He says that it does a good job of protecting/prolonging the life of the base (which I am guessing it helps prevent the fines from blowing away in the summer).
I know that limestone is part of the base and I have wondered about adding additional aggregate to the top, but I have not seen any long term roads done this way.
Anyone have any experience using washed limestone as a top dressing?
BTW, I appreciate the recommendations, but recycled asphalt is not a good option where I am at.
Also, as reference, in Central Texas, I am paying $30/yd for base delivered and he is quoting $33/yd for the washed limestone.
   / Washed Limestone as top dressing for roadbase in Central Texas? #2
Limestone is a soft rock. It breaks down fairly quickly, but it also varies from quarry to quarry. If possible, try to find crushed concrete. It is much harder and holds up a lot better. Not cement wash out of the concrete trucks, but the stuff that is actually old concrete that is run through a crushing machine to break it down.
   / Washed Limestone as top dressing for roadbase in Central Texas? #3
If you find crushed concrete, they have to do a good job screening it with a magnet. It typically has metal in it too (at least what I get). Even though what I get supposedly has had magnet thru it, I will pull lots of pieces out that I wouldn't want to drive on.
   / Washed Limestone as top dressing for roadbase in Central Texas? #4
Limestone and crushed concrete vary in quality based on region. I will defer to Eddie in Texas, but in Ohio limestone is superior to crushed concrete
   / Washed Limestone as top dressing for roadbase in Central Texas? #5
Probably is everywhere....but crushed concrete is pretty inexpensive compared to any type of stone and the high % of fines lock it together pretty well once it's packed down.
But has plenty of drawbacks too..... I use it only due to the lower cost. $/ton really adds up quick.... Southern TX Jul-Sep might be so hot & dry that rules out crushed concrete just due to excessive dust?
   / Washed Limestone as top dressing for roadbase in Central Texas? #6
1 1/2" sounds kind of large. I've typically seen that used for the base and then 3/4" unwashed on top. There's a member here on TBN (BigJohn I think) that does gravel driveways for a living. He's out of North Texas, but would know what to use.
   / Washed Limestone as top dressing for roadbase in Central Texas? #7
My opinion is use crushed limestone WITH the fines in it, washed limestone is just loose rock and will never pack down and get tight.
   / Washed Limestone as top dressing for roadbase in Central Texas? #8
Washed limestone makes a poor top dressing because it will compact but it won't consolidate.
In other words, if you spin a tire or turn a steering wheel or even drag a tree branch, you will have loose rocks on top.
   / Washed Limestone as top dressing for roadbase in Central Texas? #9
I own a farm around the Buffalo,NY area and all of my driveways and parking areas are crushed limestone. I also put in driveways as well. Washed limestone won't compact enough for what you are trying to do and 1 1/2 is to big in my opinion. A smaller crushed limestone will compact very well and the dust from it will harden it like concrete after a few rains.
   / Washed Limestone as top dressing for roadbase in Central Texas? #10
The crushed rock from Central Texas won't last for road topping. You need the rock from Chico TX, or equal, as it is much more durable. For our driveway I use the Blum TX area road base as it is closer and cheaper but the Chico rock to "seal" it from road traffic, 3/4" as already mentioned.
2023 Isuzu NPR S/A Dump Truck (A56858)
2023 Isuzu NPR S/A...
(11) Assorted Steel Rims (A57454)
(11) Assorted...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
John Deere 204L (A56436)
John Deere 204L...
