LAWALLSTRACTOR
Veteran Member
I should move, the economy here is bad and our area has been given the award for being one of the highest taxed areas in the country.
Oh, I'll bet we've got you beat on taxes. And if we don't right now, just wait a bit. Our brand new "tax & spend" governor is completely out of control.LAWALLSTRACTOR said:I should move, the economy here is bad and our area has been given the award for being one of the highest taxed areas in the country.
Congratulations on Post No. 700!rback33 said:Just make sure that the pin does not have so much play that the hex head of the pin can slide outside the pintab (hex shape on bucket that prevents turning). While it is minor, this would likely cause increased pin wear. We don't want unnecessary expenses encroaching on your next new toy, I mean tool, fund.PS.. Woo hoo... this was my 700th post!
The washers are loose and painted red... and there are no washers on the skid steer setup at all (other than the lower "washer" that's really part of the BLI tube assembly).rback33 said:Doug,
It's actually hard to say for sure.... if the washers are loose on the EClip side, then they are NOT OEM. If they are welded to the boom, and I think we did this at one time, then obviously they are. On your Skid Steer set up I would not expect to see loose washers though. Send me some pics if you can so I can get a better look at it.
Dougster said:The washers are loose and painted red... and there are no washers on the skid steer setup at all (other than the lower "washer" that's really part of the BLI tube assembly).
In the forward top portion of the boom assembly I have the following situation:
Right Front Pivot Pin - BLI Rod Assembly upper "washer" only - Very tight fit but clip is seated
Right Rear Pivot Pin - Loose Red Washer - Minimal Play - Clip seated okay
Left Front Pivot Pin - Loose Red Washer - Binding Badly - Clip half out
Left Rear Pivot Pin - No washer at all - Way too much play (I suspect this is the long pin) - Clip seated okay
Make any sense?
Dougster
I think you are right!rback33 said:Perfect Sense! I believe the left rear and Right Front need to be swapped. Left front should have the washer removed. I have no clue why those washers are there.![]()
