Warning lights on a 1602D
   / Warning lights on a 1602D #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi there,
I have a grid of four warning lights on my tractor.
The top left light came on while mowing, so i shut it down.
Any ideas?
Thanks,
Rob
   / Warning lights on a 1602D #2
Not familiar with a 1602 dash but on my 2002d the top left light is a battery water level light which has had wires hooked together to turn it off. If that is what your top left light is I would suspect your wires have come apart somewhere. May be another light for all I know. Do you not know what the light indicates?
I haven't traced the wires yet, I was tired, so I shut it off and posted.
I'll take a look later this afternoon.
Thanks,
Rob
I let it sit all afternoon, and when I turned the key the light was off.
It was 95*F and I wonder if it was temperature related.
I guess I need to take the dash off to follow the wires....
   / Warning lights on a 1602D #5
Every Yanmar I have seen has a universal symbol indicating what the light is.
Pardon the dust and dirt, but here are my lights
   / Warning lights on a 1602D #7
somebody out there has a 1602 and will identify the lights.:thumbsup:
   / Warning lights on a 1602D #8
I think I see what you mean:p On my trouble lights. Say for instince Water temp sender you can remove and ground out the wire and the light comes on.The oil should come and go out when the pressure comes up on a cold start up. Sould be able to do the same. Get a volt meter and check that you are chargeing So you won't have to worry about that one. and the last or forth ??? Creeper gear just a guess maybe Low fuel.
Carey
   / Warning lights on a 1602D #9
It is the overflow tank indicator light. Pour 2-3 ounces of antifreeze in there.
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
