warning light
/ warning light #1
jonc00k
brittany France
iseki tu220f, international b414, Avto t40
I have just taken delivery of a iseki tu220f.
When it is running there is a warning light on the right hand side of the dashboard.
It looks like a battery with water in the bottom. Does any one know what this is for and should i worry about it?
The charge light is on the left side and this is ok when engine is running.
Thanks in anticipation
Jon
/ warning light #2
That is the battery water level. The Japanese tractors have a sensor in the battery. When they get here most of them are changed to US batteries that don't have the sensor. There should be a two contact plug near the battery. Take a jumper and short between the terminals and see if the light doesn't go out. I usuaully just cut the plug and wire nut the two wires together.
/ warning light
Thanks for that.
will have a look for the sender unit and wire it up.
Another question do you know which of the three PTO speeds is 540 rpm? and what speeds are the other positions?
Thanks
Jon
/ warning light #4
I haven't Tached the shaft on that model but a close reference would be:
first 560
second 750
third 950
fourth 1100
Again give or take a few rpm.
/ warning light
Cant find any wires that look like they belong to a sensor.
So I have taken the bulb out of the dash. Do you think this will be ok?
/ warning light #6
That is the second best solution. It usually takes longer than twisting the wires together.
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
EZ Trail 3400 (A63688)
2022 EZ-GO ELITE...
211453 (A62131)
211453 (A62131)
John Deere 410D Backhoe (A62679)
John Deere 410D...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
