warming up in the garage and fumes question
   / warming up in the garage and fumes question #1
Deepdrop
Bronze Member
Lebanon, New Hampshire
Kioti CX2510 (2021)
Hi,
I understand that I should let my tractor run for 5 minutes or so until the temperature gauge starts to move. I keep the tractor in my garage, so if I let it run for several minutes in the garage, the house really gets a lot of diesel exhaust fumes, which smell really bad, and probably are not really safe.
I keep a ballast box on my 3 point hitch. So, if I start it up, and immediately lift up the ballast box (800 lbs or so) and drive the tractor out of the garage, is that a lot of work on a cold tractor at low rpm's? And should I keep it at low RPM's since the engine is cold? Or is it a bad idea to make it lift that ballast box at low RPM's?
This is a Kioti CX2510 compact tractor.
Alternatively, I could just leave it outside all winter, but in New Hampshire, that isn't a great option since after some of our snowfalls, I might not be able to find the darn tractor!
Anyway, I'm hoping that some of you more experienced people can offer some advice on what will be the safest for my family, but not too hard on the tractor.
Thanks!
   / warming up in the garage and fumes question #2
IMO - 1) open the garage door 2) start tractor and let run 3-5 minutes 3) raise ballast box and pull out 4) close garage and allow tractor sufficient time for fluids to warm depending on ambient temperature in garage before start
If you raise the ballast box before the hydraulic oil is less viscous you may damage something in your rockshaft linkage- don’t ask me how I know .
Good luck.
Frank
   / warming up in the garage and fumes question #3
I wrote a reply and deleted it because I realize I am not up on modern Diesel engines and their emmissions.
But if you have a downswept exhaust, how about a hose?
   / warming up in the garage and fumes question #4
Install an exhaust port in your garage wall. Use a flexible metal hose from there to slip over the exhaust pipe on the tractor.
   / warming up in the garage and fumes question #5
I’d back the tractor outside. Driving it 20 feet isn’t going to hurt it.
   / warming up in the garage and fumes question #6
Same here. Raise the rear implement or loader a couple inches and back it out and let it warm up outside. No need to over think this...
   / warming up in the garage and fumes question #7
That's what I do. But it's rarely below 45 degrees when I am operating the tractor.
Also once the engine's started and idling smoothly I let it idle for 5-10 seconds and then bump up the throttle. Diesels warm up slow at idle compared to gas engines because there's no throttle restricting air flow through the engine. All that air carries away heat.
I'll let it warm up at ~1500 rpm and/or let it warm up as I drive it to where it's going to work.
   / warming up in the garage and fumes question #8
Well since its TBN if you let it warm up in the garage until the the wife complains then you could build a NEW shop what size do you want.......:laughing: But I would just pull it outside and let it warm up then go to work......
   / warming up in the garage and fumes question #9
I operate stuff ever so slowly after just having started cold all the time. Lowest gear, slowest possible speed, the slightest touch on hydraulic levers. You know, common sense approach.
   / warming up in the garage and fumes question #10
Exactly correct!
I do it every time!
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
