warm up time for jd 3020 ?
   / warm up time for jd 3020 ? #11
bigtiller said:
The fluid and filters were changed by the JD dealer when I bought the tractor. I have since put 124 hours on it in the 10 years I have owned it.
10 years with no fluid change????? Serious? Change everything.
Bob
PS And use your tractor more often! Or leave it at my place.
   / warm up time for jd 3020 ? #12
rdbigfarmboy said:
I might change to A thinner oil or ATF. It sounds like you may have a weak pump or other problem.
ATF should only be used where it is prescribed. In other machines it will eat away copper synchromesh rings, seals etcetera.
It is just corrosive as sh*t and you're asking for trouble if you use it where it shouldnt.
The tractor being used 126 hrs in 10 years, wore as much as my tractor running 300 hrs per year.
Oil should be refreshed every year because it absorbs moisture and breaks down. The oil in your rear end (uhh.. sorry your tractors rear end) probably looks like butter milk now.... ;)
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
