WANTING TO ADD SOME HORSES
   / WANTING TO ADD SOME HORSES #2
This is all I can think of...:rolleyes:
lol clever. although that might be against regulations, well it should be, thats to much power.
   / WANTING TO ADD SOME HORSES #5
Switch to synthetic oil. It'll add about 3 to 4%.
Ralph
   / WANTING TO ADD SOME HORSES #6
In general, you can raise the comp ratio with dome top pistons, add turbo chargers, bore out to use bigger pistons ( more CI ).. etc.. etc.. All this hotrodding takes lotsa money.. as was once said.. how fast is your wallet?
soundguy
   / WANTING TO ADD SOME HORSES #8
This port injection Nitrous oxide system will give you anywhere from 150 to 500hp depending on jet sizes. I Have one on my big block chevelle and it is just fabulous. If you are realy lucky, the engine may hold together long enough for you to hit the go button a second time. {just kidding, dont do this :eek:}
   / WANTING TO ADD SOME HORSES #9
Without knowing what pistons you have right now, There were several options, I' say look around online for a piston and sleeve set of original fire crator pistons.
I put a set in my super C when I rebuilt it along with a few other slight modifications and it was almost double the PTO HP. It dynoed at 30 once I broke it in and took it to work to try it on the dyno.
You have to get the proper distributer shaft and advance springs for the firecrators and it is all still available at the dealer. Well, it should be at a good dealer. These originally came in a boxed set with everything you need for the conversion. You can still find them if you look around.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A52748)
YOKOHAMA - GALAXY...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
