Tiller Wanting a Rotary Tiller.......
/ Wanting a Rotary Tiller....... #1
don716
North Georgia
Kubota/ B7500/with 2000 lb winch
I am looking for a 4' Rotary Tiller and would like to have an Orange one to match my tractor and was wondering what were my choices, and about what kind of prices are on new ones? What other ones is out there that are good brands.
Donny
/ Wanting a Rotary Tiller....... #2
I have a 52" reverse tine Kubota tiller. It is great but expensive. I bought as a demo a few years ago. It normally sold for $2500. But as a demo it was $1800. Here is a link to their tillers for you size tractors. http://www.kubota.com/f/products/B7410_Implements_tiller.cfm
If you have to have a Orange tiller. Consider a Befco or one of the manufactures that will paint their tillers what ever color you want. It should save you several $100 and work just as good.
/ Wanting a Rotary Tiller....... #3
Donny
4' King Kutter and a can of orange Krylon'll do the trick.
/ Wanting a Rotary Tiller....... #4
I've seen some at a Kioti dealer, I think they were made by Sicma.
/ Wanting a Rotary Tiller....... #5
A few years ago I was looking for a Kubota tiller and found a Kubota K420 at the back of a dealer's yard. It was well used and weathered but otherwise in good condition. I got it for $400. My suggestion is to snoop around - you may be surprised at what you can find.
/ Wanting a Rotary Tiller....... #6
don716:
I am very pleased with my new Carter & Carter (CCM) MR-160 (58") tiller :D. It is a gear driven model and it is a bear. They make Medium Duty CR-45 (45") rated for 10-45 PTO HP, CR-50 (50") rated for 12-45 PTO HP. They weigh 395# and 410# and list ~ $1150 and $1200 respectively. They have a a Commercial Duty MR-130 (49")tiller rated for 15-60 PTO HP. It weighs 495# and lists for ~ $1300. Shipping from TN to residential MA cost $195. I am color blind :confused:, but my wife says mine is red. They also advertise an orange model. There are a lot of threads floating around on TBN regarding tillers. Good luck on your research and purchase :). Jay
Thanks for the info.,any more web addresses for tillers? What should I look for in a rotary tiller? I was told to make sure it had a slip clutch.What exactly is that?
Donny
/ Wanting a Rotary Tiller....... #8
A slip clutch replaces shear bolts, so if you "till" something that won't, IE hickory roots, you just have to untangle instead of untangle and replace shear bolts.(and possibly straighten tines/blades)
Dart
/ Wanting a Rotary Tiller....... #9
Don,
If you want to check out used, you can usually get a tiller from people that sell grey market tractors. Around here, they get about 3-400 for a used paddy tiller. The tines are not as strong as a general purpose one, but they work well in "softer" soils. Get a copy of the equipment trader or similar, there is usually a couple ads selling Yanmars and such.
Otherwise, the KK gear drive tillers are nice.
LandPride, Kubota, John Deere also have excellent equipment but $$$$.
jb
/ Wanting a Rotary Tiller....... #10
I picked up a King Kutter XB series 4' tiller on sale for $900. They're orange. Might be pushing it with your 30 hp tractor as they are only rated for 25 hp. It comes with the slip clutch standard. Not sure if you will be able to find it as cheap as I got it, but I think they retail for only around $1350-1400.
/ Wanting a Rotary Tiller....... #12
If you want a well made, orange, tiller, at a low price, I would recommend a CCM. I have had one for 2.5 years and wouldn't hesitate to buy another. They are gear drive, have a slip clutch, and their fit and finish is better than the KK brand that my local TSC store carries.
I'll attach a picture of the tiller on the tractor.
/ Wanting a Rotary Tiller....... #13
i have a ford 105a tiller and have been using it for 15 years to till my market garden. it has held up very well even though it looks beat up. i've replaced the tines a few times.
/ Wanting a Rotary Tiller....... #15
Donny
Slip clutch is definitely good, also look for one with 6 tines per flange. I have a 48" with 4 tines and was working in the same field with a tiller with 6 tines, in one pass there was a notable difference in the finish between the two tillers, if I ever have to get another tiller, it will have 6 tines per flange, in plowed ground, they till the ground a lot finer in a single pass, I would have to make two passes with my 4 tine per flange tiller. I am satisfied with my tiller and had I not used them side by side, I would never known how much difference between the two.
Thanks, I will check out some of these web sites.
Donny
/ Wanting a Rotary Tiller....... #17
Donny
I couldn't justify the cost of a new tiller, so last August I picked up a pre-owned Yanmar RS1200 rototiller (48" wide) for $300 from my local grey market tractor guy. Added a $100 Weasler slip clutch from www.agpartz.com since I couldn't find any indication of a shear pin on the tiller. Built a gantry-type dolly out of pipe fittings so I could move it around for hitching and unhitching.
/ Wanting a Rotary Tiller....... #18
I see you finaly got your slip clutch... You wouldnt have a picture of it installed on that 12" shaft would you:D ... Did you extend the arms?
/ Wanting a Rotary Tiller....... #19
You can get one for $300-400 at Southland Equipment in SC that is close enough to go and look at it. 864-895-4220
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
213097 (A64276)
213097 (A64276)
