Want to share my work light success with you
   / Want to share my work light success with you #1
Blee
Central Virginia
Kubota B7800
I have tried in vain to establish good extra lighting on my Kubota B7800. I have seen what was here and tried some creativity of my own only to have it look bad, jiggle too much, or both. I think I have a cool solution which utilizes the empty hole in the ROPS; thereby not hitting any sensitive warranty issues. The result is (wiring harnesses yet to come) stable, helpful and aesthetically pleasing. I drilled out the exisiting holes of a heavy-duty corner bracket with a 9/16ths drill. The rest is easy as cake. Here are some pics...
The light are actually just a bit wider than the bucket, so the bucket won't block the view. Here's more detail if you blow it up.
   / Want to share my work light success with you #3
Your lights look neat and I'm sure they do a good job for you. Unfortunately around here they wouldn't last very long. The trees around here tend to knock off anything that's outside of the ROPS.
   / Want to share my work light success with you #4
How did you do the wiring - just hook it up to the loose wires in the harness at the back of the seat? Or did you run another wire from the terminal block.
Also did you upgrade the alternator? I'd bought my lights but it got too cold up here to work on them.
I like your solution. There will be a copy here soon.
   / Want to share my work light success with you #5
Great looking job ! That's a good design and it should serve you well. Carry on!
Cheers!
   / Want to share my work light success with you #6
PineRidge is right about those trees. I was in my woods Sunday and a branch reached right over the fender and broken a lens and blew the bulb.
Ah! That's the beauty of the ROPS holes. Just by removing the 9/16ths pin from the ROPS hole, one can change it to be inside the ROPS or even the extra hole when the ROPS is down.
I chose to keep them outside because the light is not blocked by the FEL. I think that in the spring, I will change it to inside the ROPS bar.
I took the lazy-man's approach and spliced the lights into the tail lights (which only come on if the headlights are illuminated.
I do have the alternator upgrade. I knew (being literally blind in one eye and can't see out t'other) that I would need additional light to be safe, secure, happy, and... oh, yeah... be able to tractor by moonlight!
Thank you for your compliments -- they mean a lot coming from you guys.
Blee
   / Want to share my work light success with you #8
Looks good.. what brand lights are you using?
   / Want to share my work light success with you #9
Nice setup, very tidy /forums/images/graemlins/cool.gif I had mounted mine to the pre drilled holes in my Case ROPS but my mad bomber winter hat blocks some of the light. Trying to come up with a hinged setup that will allow me to keep them inboard and swing them out for winter night use. Still thinking /forums/images/graemlins/tongue.gif
Geez, I am not really sure what the brand name is. They are plentiful at the local TSC. Come spot, trapezoid, and flood. Not sold on trapezoid, but too early to change yet.
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2015 Chevrolet 3500 HD (A50120)
2015 Chevrolet...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2006 Ford F-150 Pickup Truck (A50323)
2006 Ford F-150...
John Deere 3033R (A50120)
John Deere 3033R...
