Want to add a 40 loader to my JD 445
   / Want to add a 40 loader to my JD 445 #1
atomiccowboy
What do I need to know? I have found one for $1000 I am going to buy it. What will I need to get it running? Any help would be great.
   / Want to add a 40 loader to my JD 445 #2
The loader should come complete with the mounting tube that goes on the frame of the
tractor. Also, a new unit would come with a new pressure relief valve to be put on the transmission,
but you may not get that buying used. It is required by JD to reduce transmission damage
from having the loader on the tractor.
If you get a book you will be all set
   / Want to add a 40 loader to my JD 445 #3
The pressure relief valve for the loader is not cheap. If you are buying the loader from the owner of the actual machine on which it was attached, you might offer to swap your pressure relief valve, your pressure relieve valve release lever and the 4 rear end mounting bolts (loader mounting brackets requires much longer bolts where it attaches to the frame at the rear end) for his. When I purchased my model 40, the seller recommended I bring those with me for an even swap....I'm glad he suggested it!
frencht
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2017 Ram 5500 Service Truck, VIN # 3C7WRMBJ9HG711025 (A57453)
2017 Ram 5500...
case 370 glass door never installed (A56436)
case 370 glass...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2019 KENWORTH T680...
